FIT platforms are part of
the OneLab Experimental Facility
Create your account through the R2lab portal, or login if you already have an account.
Build your own application, in your way, from scratch, or based on open-source libraries and linux OS.
Deploy and run your experiments using NEPI: Network Experiment Programming Interface
Create your account through R2lab interface, schedule your experiments and manage the resources through the dashboard control
At your time... in your prefered day! With few clicks the whole platform are entirely available for your tests.
Load your OS image to each node and control all the activity during the experiment.
Deploy your own experiment as you desire or launch NEPI tool and simplify your experience.
